Hello everyone,
I've read thru this thread and have some questions. I have a O-360 in an experimental backcountry super cub that is running high oil temps, 230-235 or higher with OAT 100*f. I have checked the temp gauge with a temp gun after flight, I haven't checked it with sending unit heated in oil but seems accurate according to readings on the heat gun. It is a steady temperature increase at any power setting straight and level, won't cool off when I reduce RPM to 2100 or so. CHTs are around 370-380. Cylinder compressions were all 78-79 at last inspection in June. I just changed the oil and checked the filter, no metal found. I removed the vernatherm and tested it in heated oil, it didn't start to move until around 215-220 so I replaced it. The old one does not have a complete 360 degree witness mark and the seat looks wrong.
Does anyone have a copy of Lycoming service instruction 1316A? Will this create a high oil temp situation as described? Here are some pictures of how oil cooler is mounted.
After I changed the vernatherm I flew for about 30 minutes after a brief rain shower here in south Texas, OATs in the low 80s and oil temps around 220. Baffling seems good, left side seal,
Right side seal,
The oil cooler has a 3" hose running to it, will a 4" hose help? I have the material to put 4" SCAT to the cooler but the heating problem wasn't noticeable last summer, probably because I was in NE PA, didn't get as hot up there. I would like to address the vernatherm seat after I get a copy of the 1316A. Is this set up wrong for the heat of Texas or should it be sufficient if everything is working correctly? I know its a lot of questions, but any help is appreciated,
thanks in advance,
