Gregberger1
I’m currently replacing a cracked oil screen housing on an O-320-A2B. Part number 62815. The unit currently installed on the engine has the oil probe installed in the port. Inside that port is a conical seat that the probe bottoms out against. I’ve gotten two different replacement housings that are lacking this seat in the housing port. Has anyone run across this issue before? Without something to tighten against obviously the housing leaks. I’ve looked at the old hosing as close as I can and I’d swear the seat is machined into the port.
