ADK_Cub
Hello all![emoji1366]
I normally just read and observe, but I am truly stumped with this problem and am in need of some help big time. Ok right too it.
Engine is 0-320, fresh back from major overhaul with less than 5 hrs on the break in, from a very reputable engine builder. Remote oil filter previously installed.
Start the engine makes great pressure, run up, take off and rip around the patch 5 times or 10 minutes everything is fine (2400rpm). Shortly after that the problems arise. Pressure starts to slowly decrease, panel mounted gauge and “tee-d” in gauge to the right front oil galley. Panel gauge spikes 10psi intermittently as it drops over the course of 10 minutes before it gets to 45-47psi and we chicken out and land. Suspect that the cheap tractor gauge, and long input tube for the tee in gauge hampers the detection of oil pressure spikes. Have not tested oil temp bulb for accuracy yet. Oil s
On final and in reduction of power 1100-1500rpm pressure comes right back up to green arc and stabilizes. Wtf
Sump screen clean and inspected, pressure relief valve, has new spring and is shimmed properly, no change. Oil temp by pass was both left in and removed for different test flights, no change. All oil lines clean and unimpeded. New oil filter, and purged input line to panel gauge, no change.
Can’t figure this one out for the life of me.
Stable first lap or two
Pressure drops
On final
Hopefully those post correctly. Any help would be greatly appreciated. Cheers [emoji482]
Pressure drops
On final
