Caution, you must have a "cents" of humour or you'll cry.
I hope I'm in the right place for this thread.
I have asked Lycoming about this problem already but I'm no wiser, so I thought I'd ask "group intelligence".
So here we go, I have foolishly bought another aircraft that was junk from a dead guy that I talk to a lot but get no answers yet. The aircraft was flown "apparently" with a bent crank for some time, it shook the gizzard out of it, there was a substantial amount of silicone within and without the engine and airframe (*** why did I buy this thing). Anyway what's done is done. So I have gone through the aircraft and patched and fixed things, removing silicone, mouse excrement and patching bear damage. I sent the engine case out to have it overhauled because it was fretted badly. I put another standard crank and bearings in it, new lifters, cam, rods, mags, ignition wires etc. overhauled or new. I did NOT have the accessory case inspected, the pump looked OK, in fact, after I put the engine together, I had the plugs out and flipped the prop over by hand and had oil pressure in about 15-20 flips. So after I felt that the oil was well through the engine and fiddled around with a few other things, I fired it up, it ran smoothly oil pressure came up to 65 at 650rpm. I let it idle for a while and shut it down to see what might be dripping or anything unusual. Everything was OK so I ran it again---
rpm 1000, oil pres 85lb, oil temp 160, cht 110c;
rpm 1700, mags checked OK, oil pres 75lb, oil temp 165, cht 150c;
rpm 2000, oil pres 70lb, oil temp 165, cht 150c;
rpm 2300, oil pres 65lb, oil temp 165, cht 180c;
rpm 1000, oil pres 85lb, oil temp 175, cht 190c and cooling for shut down
Emailed Lycoming asked them what's up but other than saying it could be a crack somewhere on the intake of the oil pump, a gap in a gasket ( they didn't say which gasket could be responsible for this outcome), or maybe I put the wrong oil or an additive in the oil and it's foaming (negative), they didn't have any other suggestions. I don't think any of that will actually explain what's going on. But foaming might explain it if I had put to much oil in it, I used 6qt. of Phillips66 av-oil.
I took it up for about 10 minutes but the it never made any difference, 60-65lb is all I got.
So I'll rest my case there, and think some more before I tear it down.
My little brain just can't come up with a scenario that will explain this. Maybe someone out there may have experienced something like this.
You have probable guessed this is not a certified aircraft, and I have a weakness for junk.
Robert
Robert
