FYI - O-290-D2 tidbits...
For informational purposes only -
Hastings makes rings of the proper type and dimensions:
Top rings - (Keystone type 372 ) compression ring : P/N 40651 (Chrome); 40653 (Plain) Note: Do not use chrome rings on chromed cylinders.
Oil - 3/16" (multi-element type 860 / 732) Oil ring Rail P/N 26374 (2 ea required); & Spring P/N 02221 (1 each required).
Ends up costing about $60/piston total.
For plugs I'm using NGK AB-6. NGK P/N 2910. Plug Gap - .028” (0.7mm) They screw right in and are of the proper length. (About $2/plug)
NGK AB-7 are an option (they are a bit "colder" than AB-6 if the operational environment warrants them) NGK P/N 3010. Plug Gap - .028” (0.7mm)
Modified my Bendix mags to take Accel 8.5mm Super Conductor spark plug wires. Fairly easy to do, actually. These wires are shielded and I wouldn't use any other type of auto plug wires.
