zenairdave
Ontario
So it's winter and oil temps are nil, and the dreaded run rough at full throttle on climb out has stricken me. In the process of reading all the wonderful possibilities I got to wondering.
First off, my application is Experiamental CWC, J3 open cylinder with O-200A
I have turned this kind of into a two part problem.
First , what changed?
Outside temps means engine is running much cooler. I have used Mogas all summer. (no extra additives)
My thought is I have a valve not seating completely when the block is very cold. (after chasing down fuel flow to carb, carb heat, spark plugs).
Then I started looking for ways to "warm" up the engine while operating in the cold.
This is the theory part of the problem next.
When safely on the ground and back at the hanger and trying to figure out what is going on, I noticed that when carb heat is not being used, it gets dumped out the belly of the engine cowl. Same goes for cabin heat.
Is there a really good reason that the cabin heat or carb heat when not being used (applied) could not be plumbed to the front of the carburator and let it warm the exterior of the carb so to speak?
Then I looked for ways to keep the cold out of the enqine cowl
The engine cowl has room around the air intake which allows cold air to blow in and hit the carb, I have since sealed this area up but have not flown since.
This plane struggles to show 140 degrees oil temp in the heat of summer so blowing the unused heat around the carb and then over the oil sump seems to me would be a win win deal.
Carb ice would be less likely if the carb is not frozen from fresh air and fuel vaporization which would make the application of carb heat needed far less.
Am I off base here?
Am I off base here?
