Barton
Longview, TX
I just bought a modified PA-12 and am getting back into tailwheel flying after a long absence. I have about a 1000 hours of tailwheel time with several hundred in J-3, Stinson 108, Pacer and PA-18 so I'm not a newbie at this but my new airplane is making me scratch my head.
This is a 47 -12 with a stack of STC'd mods including 150hp Lycoming 0320-A2B, PA-18 flaps, Atlee Dodge -18 landing gear with 3" extension and Alpha Omega Suspension, 850x6 tires, -18 tail with Dakota Cub trim system which includes an up spring on the elevator control and a bunch of others that probably don't relate to the issue I'm having.
Basically this airplane seems to take an inordinate amount of back pressure on the stick in slow flight, meaning anything less than about 80 mph. Starting at takeoff with trim just slightly nose up the back pressure required to lift off at around 50 mph indicated is substantial, it gets progressively lighter as the speed increases to the point that at around 90 mph it's "normal". The airplane will cruise about 100 mph at 2350 rpm with the trim indicator set one mark up and stick forces are nominal. Pull power back and the stick forces increase as the speed decreases. Pull in a notch of flaps at bout 80 and the forces are reduced, pull in another notch and it seems to be about right. Pull the third notch at about 65 indicated and it might even take a bit of forward stick but as the speed bleeds off in a three point landing attitude it will continue to increase all the way to touch down at around 40-45 indicated. Keep the power up to about 1500 rpm with 2 notches of flaps on a three point landing and the stick still gets heavy but not uncomfortable . When I first flew the airplane with the seller/builder in the back seat (185 lbs) it took two hands on the stick to get it to fly down to the stall somewhere less than 40 mph indicated. Oddly enough it doesn't seem to make much difference if my 100 lb wife is back there or even solo so it doesn't really seem to be a CG issue.
I'm perplexed by the fact that this airplane seems to need flaps to do a three point landing otherwise the stick forces are so high that it requires full nose up trim. At that point if you add flaps or power the nose pitches up and you're rolling nose down trim into it. Is this normal? Apparently the seller/ builder just did wheel landings and rolled it on between 65 and 70 so he didn't see a problem but to me it seems if you're going to put a bunch of stuff on an airplane to make it capable of landing on a back country strip or a sand bar you shouldn't have to land it a 70 to keep the stick forces nominal. I mean that with this airplane even with 2 notches of flaps the back pressure required to three point it is significant to me and my wife is pulling real hard on it. Makes it hard to move smoothly and consistently, she tends to jerk the stick because each movement requires a conscious effort.
Any input our advice would be appreciated .
