B.D.
Hello everyone; first forum post here. I'm playing around with some designs for skis; if I can figure out something that works well, I will probably end up taking it to market.
i) The first thing I have in mind is that they must be inexpensive. One big turnoff to getting onto skis is the cost of a new set, which can be upwards of $8000 for something the size of a Maule or 180. I know there are cheap Schneiders lurking around, but those are heavy and no longer in production, making it a scavenger hunt to get paperwork or parts from other owners.
ii) My next great debate is hydraulic vs penetration. Hydraulics are less draggy but heavier, take longer to install, and IIRC requires an AME to sign off during changeovers since hydraulic lines are being played with. Penetrations are draggier, lighter and easier to install. Hopefully, I can get some feedback in this area. I had thought about using quick-disconnect fittings and using the argument of them not losing fluid when disconnecting in the STC, voiding the need for an AME, but I have yet to see them work, so I wouldn't know. Or maybe I should avoid hydraulics altogether and do something with cables that use the same plumbing as water rudders in the seaplane configuration?
iii) Another thing I have in mind is being able to use *almost* any size tires, saving the cost and hassle of having to buy one specific set of Goodyears as other manufacturers require.
iv) Include ready-made rigging in the package.. saves everyone time and a headache.
v) They need to be easy to work on (ie replace UHMW bottoms, keels, change hardware to fit one airplane to another). Also need to be sturdy, all of my designs so far have a stub axle and inside mount bracket. Far less risk of them breaking off.
Summary: Trying to find the best compromise of lightweight, best performance, strength, low cost, easy to mount and dismount.
Any and all feedback is appreciated.
Thanks in advance
BD
Thanks in advance
BD
