BENEFACTOR
I am putting it down smooth with no grit added, other than what blew in when we started getting asphyxiated by the fumes. We have a little texture from the roller.
The gray epoxy went down good but we got what looks like fish eyes in the second half of the clear. I ran the AC all night to cool the slab and we worked in the AC till we couldn't stand the fumes and opened the door. Once we were done we closed the door most of the way and turned the AC on. We have had way more humidity than usual. Robbie couldn't figure it out after do some test areas with the same batches. He sent me some more clear and we will try it come Fall. It is doing it's job at the moment, I can wipe oil and stuff right up. Easy to keep clean, I ended up buying a dust mop.Curious what you think of the Airtech coating, I assume you are putting down a clear coat too?
For sure, been well over 100, highest was 111, for several weeks and our lows have been 80-82. I run the AC at 74 degrees all night and then down to 68 when I get up. It will get up to 84 on bad days. We are a 5 ton unit where the computer model called for 6.8 on the 110 degree days. We started putting the t on mini split in on Friday and I started wiring it today. Had a Stearman come in early the other morning and between letting it in and out and a friend in a wheel chair we opened the door 4 times before lunch it still stayed below 83. I priced 8" of fiberglass for the whole hangar for $7k but will wait to fire the mini split up first. been working in the old hangar on a fuselage early in the morning and when I get too hot I go in the new hangar and work on annuals. I can't bring myself to bring the fuselage jig, welder, grinders, sanders and saws in the new hangar yet. We have gotten way more work done because of the AC, I would not want go back now. The older I get the worse I hate summer.Enjoying the AC yet? Holy krap it’s hot and muggy here.
Just did daughter and SIL’s new garage with Rexthane (Sherwin Williams 1-part urethane) and shark grip additive in the second coat. I like it a lot. Mine’s next but it’ll have to cool down for me to do it. I may hire a pro who’s used to these temps.
Mr. Pierce;
I recommend the insulation - any insulation. It will pay for itself in time and is good all year round. You will be amazed how little climate control you need with a well insulated hangar. I've got 2 inches of spray foam on mine and I almost never use the heater I paid big money to have installed. And even in triple digit heat it's very pleasant in there - with no AC. To be fair I did have to put AC in the room where I keep the batteries to keep them within operating temps. We're 100% solar here so I've got to take care of those batteries. But that's just because of the heat all that gear generates.
Insulation also has the advantage of making the place quieter. You don't realize how much fatigue noise adds over a long day of work. Mind you, I try to avoid work, and especially long days of same, but that's just because I'm a lazy ne'er do well - not because of any climate issue in the building.
