skywagon8a
MEMBER
SE Mass MA6
Perhaps you can press on the edges of the flat glue strip enough to be able to see were the rib cap strip is located. You will develop a process. Good luck, you have a big job ahead of you.
Mark rib locations and hole positions with a straight edge and pencil before drilling. Due to the wing curve, your hole spacing frim top to bottom will very slightly. Do not use a soldering iron on the fabric. The melted fabric will make a hard lump and be visible in the finished product.ok.. so get a bit the size of the stitching - not sure how I'll not hit a rib eventually - given the number of holes to drill where I can't see... probably should use a soldering iron first to cauterize the fabric hole?
Thanks for all your help by the way!
Aircraft Spruce calls them Ceconite Reinforcing Tape and Linear Pinked Tape. I use PolyFiber Poly-Tack glue, haven't tried any others.Anyone know the name of the reinforcing strips of tap that goes on top of the fabric on top of each rib... that I will then tie the knots over the top of? Also, the best glue... and the wide strips of tape that covers over the stitches that can then be painted? My daughter is meticulous and awesome at jobs like this... we'll do it together.
Take a good look at the rest of your wings. Is the glue still holding the ribs together? How about the rest of it? It's a big job, but if all else is satisfactory, just strip off the fabric, cut off the overhang of those wide strips and recover the wings.I stitched the first rib after the tank… I don’t think this is going to be the way to go for various reasons.
The fabric seems to hold well glued to the 1” wood strips which the builder glued to the top and bottom of each rib; however I don’t trust it.
Looking for replacement wings :-(
The glue seems to be rock solid on every rib. What started this was that the original builder did not wrap the fabric around the root ribs, but cut the fabric flush at the edge. Then he didn’t secure the middle of the trim that covers the gap between the fuselage and root rib. Consequently it vibrated enough against that non-wrapped glued fabric on top of the root rib and eventually it released there only.Take a good look at the rest of your wings. Is the glue still holding the ribs together? How about the rest of it? It's a big job, but if all else is satisfactory, just strip off the fabric, cut off the overhang of those wide strips and recover the wings.
That would be a lot more work than recovering your current wings like Skywagon suggested. Extending a set of Tri-pacer wings would be more work than building a new set of wings from scratch.I may have access to a set of Tri-pacer wings. If I pick these up, I understand that I will need to extend these like 3 feet or so.
Is this a pretty straightforward upgrade to Tri-pacer wings?
Interesting… that’s surprising that it would be more work to extend Tri-pacer wings than to strip the fabric off my existing wings, cut down the strips from every rib, then re-fabric, and rib-stitch the wings.That would be a lot more work than recovering your current wings like Skywagon suggested. Extending a set of Tri-pacer wings would be more work than building a new set of wings from scratch.
You know how your current set of wings fly. They are trammeled, you know your strut adjustments. That won’t change with Skywagon’s suggestion. Moving to a modified set of Tri-pacer wings and you are test flying from square one to get things set up correctly.
