adamgrenda
King Salmon, AK
My experimental cub was built in 2010 with Stewart’s system. It’s a great airplane and it looks good. It has some patches, duct tape and the typical rash of being a working hunting cub. However I’m concerned with the longevity of Stewarts system... I’ve had blisters that come and go that I just leave and hope they go away. A few I’ve popped and peeled the paint back and sanded and put down ekofill then ekoprime.
Overall the fabric doesn’t seem very flexible. If you push or pull anywhere it cracks. The stringers are all cracked down the tops and some on the sides of plane. The pull handles top coat is all cracked around the area. I’m not so concerned with the cosmetics of it I just want my fabric to last.
I can hold a headlamp light up to stringer and look through aft baggage door and see some light. Is that concerning? I have seen fabric much worse but my cub lives outside most of the year and I know what just a little UV can do.
If I can see daylight through stringer cracks what do I do? Do I lay new tapes? Do I sand and then lay more ekofill down? I’m not sure at this point. Called steward and they said they had some bad batches of paint around 2010 or so when this was done. Paint comes off when I pull the gorilla tape off in the winter months to patch it almost seems like I should just leave it on!? What about the vinyl guys are using to cover up some spots instead of a fabric patch?
Thanks.
Thanks.
