Wow, if you are going to be doing all of those mod's you will be out of time and money, if you are like most of us, before you get north of the border. My 2 cents worth. Fly the plane you have right now with as few mod's as possible. You'll save money and weight, After your trip you will have a lot better idea if you ever want to do that again and if you do which mod's you really want. But in the meantime.
*spent a few bucks on an Oregon aero bottom seat cushion, you can thank me at about hour 8
* replace your leaky tank with a Wag aero 18 gallon tank, pressure test it for sure first but the first generation ones got the bad rap, I put in a new one a few years ago and its worked great. The 30.5 gallon tanks are too big for most uses, the Dakota cub 24's are great but require wing removal, removal and replacement of a few ribs and new compression members, again a good thing to do if you want after this shake down cruise, but lots of work and something best done when you are also adding flaps at the recover...Been there done that
*safety cables only work with pa-18 style gear which do require welding new ear tabs on the front fitting. You could replace the original 16 guage cable in the bungee area with a beefer size if so desired.
*the borer prop requires at least 850's which will require a field approval unless you go with 18 gear, no STC available for 850's on original 12 gear.. Catto prop's aren't STC'd for certified planes yet.
*I personally don't think you need inertia reels, regular shoulder harnesses by Hooker work great, be sure to get the seat belts that adjust on both sides of the buckle for better comfort. If you attach it with an 'H' bracket to the cross bar above the rear seat you don't need a fancy costly attachment bracket, nor do you need to do any welding.
* did I mention getting a good front seat bottom cushion....
