skywagon8a
MEMBER
They both are boxy airplanes. The Found doesn't have a wing strut.It looks like a Found Bush Hawk with a turbine.
Lockheed Loadmaster with PT-6 conversion. https://www.aircraft.com/aircraft/200973513/n7240k-1997-lockheed-loadmaster It used to live not far from here in Hinckley, MN
Well it does look like this airplane. The paint job almost matches. The N number has been changed. According to the FAA the deregistered N7240K was on a King air and previously a PA-18-105. https://registry.faa.gov/AircraftInquiry/Search/NNumberResult?nNumberTxt=7240k
The current N2719E is a Schneider Loadmaster experimental Amateur Built. https://registry.faa.gov/AircraftInquiry/Search/NNumberResult?nNumberTxt=2719e The data plate verifies this. I did not see the big EXPERIMENTAL posted on it. Perhaps it is inside the doors?
It does look like what is described as the Lockheed. The Lockheed 60 was originally designed in the late 1950s to be manufactured by someone other than Lockheed, originally in Mexico. I remember seeing one in Anchorage in 1972. Do you suppose that Richard Schneider modified a Lockheed 60 so extensively that the FAA allowed him an EAB airworthiness? I did not see a data plate with Lockheed's name on it. Is this the same Richard Schneider who lived in Eagle River and was known for his racing slick bush wheels and skis?
Look at the Murphy Moose with a PT-6 here: https://www.murphyair.com/moose/
That does explain the different N number, but the FAA's record of the old N number doesn't match.Looks like it was for sale in Canada, I would assume it came back and got a different n number
Before the rebuild: https://abpic.co.uk/pictures/view/1104176
That was my guess too. Look at the prop, it is counter-clockwise rotating as is the Ivchenko on the Yak.Looks like a cowl for a round engine--
in fact, looks almost like the cowl off a Yak18T.
I wonder which engine it had?
