I am looking at buying my first Supercub PA-18-150. The plane was restored recently and is at a very good price. Unfortunately it is very stock and some of the basic modifications aren't done like the cabin roof X-brace although it does have large bushwheels. I am interested in being able to fly with floats and using the plane to take me backwoods for camping and that leads me to thinking I should have the Wipaire 2000 gross weight STC done and the float fittings. The Wipaire STC seems like it can be done with relatively minimal work to the covering; it looks like a H cut to the cover on the wing. I would also like to add the cabin X-brace to the frame so it is a little safer. Considering that I got it at a good price, what other mods could be done without significant recovering? The things I would really like are X-brace, 2000lb gross weight STC, float fittings, provisions to mount a bellypod, 180lb baggage/third person STC, extended baggage, removable rear seat crossbar, and a control lock. I am afraid the bellypod provisions, 180lb/third person STC, and float fittings may take a lot more cover work. What are the best and earliest things I should do to maximize ease of use, handling, and safety in the backcountry? Are there other mods I should do that really are great from a regular use and utility perspective? I plan on keeping the plane for a long time and I don't want to have the plane to look like Frankenstein with all the scars and stitching all over the place too early in its life. I copied and made some edits to a list of potential mods from another thread.
Reverse Dog Leg
Extended Baggage
Metal Belly
Removable Rear Seat Cross Bar
Cargo Tie-downs
Float Fittings
Float lift Rings
Dual Tail lift handles
Firewall X Brace
Cabin Roof X Brace
Seat Belt floor Attachment
X-Brace at Turtle Deck above Lifting Handles
Flap Handle Mods - notches
Extended Front Seat Attach Tabs
Tail X-Brace
3rd Seat Reinforcement/STC
Extended Stick
Folding Front Seat
Control Lock
Parking Brake
Extended Baggage Door
Upper Cargo Bay
Metal Headliner
VG's
24 gallon wing tanks
Defroster
Rear Seat Heat
Left Window Slider, Fixed, Folding
Borer Prop
Battery Location (Underseat)
Lightweight Starter and Alternator
2000lb Gross Weight Mod
Rear underseat Storage Box
LED Strobe Lights
Upgraded Gascolator
Brake Boosters/Upgraded Brake Master Cylinders
Reverse Dog Leg
Extended Baggage
Metal Belly
Cargo Tie-downs
Float Fittings
Float lift Rings
Firewall X Brace
Cabin Roof X Brace
Tail X-Brace
Extended Stick
Folding Front Seat
Control Lock
Parking Brake
Upper Cargo Bay
Metal Headliner
VG's
Defroster
Rear Seat Heat
Borer Prop
LED Strobe Lights
Upgraded Gascolator
