The RANS S-7 has what I believe is properly referred to as "plain" flaps. Not to be confused with plane flaps. They hinge at the trailing edge in such a way that is simple, light, and easy to manufacture. They are effective also, and the thing lands plenty slow, but it has occurred to a few of us that just possibly, VG's on the upper surface of the wing's trailing edge, about 2 " or so from where the flap is hinged, may help keep the airflow attached to the upper surface of the flap when it's deployed. This assumes the ones already in place on the wings LE are too far away to directly energize the flap surface. Similar to what they do on the hor stab/elevator.
I am sick of reading about the double slotted P flaps advantages you Cub guys can bolt on by simply writing out a check, (and I don't want to take on the task of engineering something similar for the S-7, that's beyond my ability most likely and I'm too busy anyway) and I'd have a set of those tomorrow if I had a Cub. BUT, I can ably layout and install VG's, using double sided carpet tape for experimental purposes. What you think, been done before, a waste of time? I don't want my plane to be laughed at! BTW, I landed three new 8K plus sites the other day, it does alright as is, but a bit more drag and/or more lift at certain flap settings would not be a bad thing.
