Lyc 0-235 running too cool
Wrenchgirl
A friend has a 0-235 in his Citabria. Oddly enough, he is concerned his oil temp is too low. Does anyone have experience with a baffle covering plate on this engine to increase oil temp? Thanks for any input.
A swatch of duct tape on the cooler is the easiest solution. Either that or a bunch of money to convert it over to a Vernatherm. I did the Vernatherm swap several years ago and it rewarded me by failing in about 18 months. I'm back to using tape on the cooler, and it works just fine.
I would agree with PerryB. It is very easy to cover make a plate for the cooler in a o320 usually 1 inch of duct tape = 20 degree of oil temp increase. I would not want to cover in air inlet to the cylinders unless he had a 4 cylinder CHT/EGT.
There could be a box that goes over the oil screen housing and has a scat hose blowing air on the screen housing. I've seen this on a Piper Colt, doesn't drop oil temp, just cools the housing and temp probe to lie to the pilot. Worth looking.
Thanks for this great tip. I need to get to his airport and take a look at the whole set up. It's been airplane crazy around here so I am hoping to get there this week. Also need to investigate just what his oil temps have been. I have been reading here that temps 180-220 are acceptable. Comments?
My '69 7ECA w/O-235 didn't have one either. Never knew I needed one until I saw a plane that had one.
Well I don't have much time working on Citabrias but they sure are fun to fly. Looking forward to learning about this. Appreciate the feedback
The TCDS is exactly where I was going to start. I just noticed this group's name came up when I began discussing the 0-235 so I started here instead. But I Ned to go to the TCDS and explore that. Thanks for your input.
FIRST STEP!... is the gauge reading ACCURATE???? test it, cold(and dark, out of sun) = ambient air temp or in boiling water = 212F ... MANY ARE OFF....
Pretty normal. In 1948, Cessna had high oil temps when certifying their new model 170 with the Continental C-145 engine. They added a blast tube blowing on the screen (where the temp probe is located) and everything was good.
Thanks for your input. When I get to the hangar I will look for this. Other folks have suggested a scat hose aimed at the screen housing might be the culprit. And just what we need....instruments lying to the pilot. Yikes! Really appreciate your response.
Another place to put the bulb for the second temp gage is in the oil drain of the Continental oil tank. The drain plug thread is the same as the oil temp adapter thread in the back of the oil screen. Somebody did that, maybe Bill Pancake, and I thought that location confirmed the blast tube did lower the oil temperature a bit. I don't understand how the blast tube could cool the temp bulb in the center of all that hot oil without cooling the oil surrounding the bulb, too. Unless-- if the tube to the gauge is cooled or heated will that change the reading on the gauge?
The data I posted came from Jerry Burr. If you knew Jerry you would take the results to the bank. Theory is one thing but when you take the time to build and test it you get real world results.
I must live in the wrong part of the country. (Well, I KNOW I do but that's another issue.) Good for you guys that you have/are these resources. It's just golden to have someone to go to with this. I had a guy like that for my WACO UPF. Practically had him on speed dial. I really appreciate all the hints and advice.
I have a TaylorcraftF21 with that engine and no oil cooler. Cold temps are a problem in the winter. Temp gets to 120 max. In the heat of summer and on floats the hottest it ever gets is 190. Try duct tape over a portion of the air intakes, a little at a time and you can get the temp up to 150.
Jim
Jim,
Thanks for that. This has been a recurring suggestion. Where is the tape most effective....front of the cowling on either side of the spinner? Taking care, of course, to keep it off the cooling fins. And yes, I would put some on, go fly, and repeat. I am concerned this engine is not getting hot enough to burn off all the condensation. Might just take the boroscope and peak into the cylinders. Do you think 150 is hot enough? Seems as tho the threshold ought to be in the 180 range. Maybe this just isn't possible in the winter.
Several factors involved with removing moisture from oil. How often and for how long comes into play. If he is doing long flights 150 degrees may be getting rid of a lot of the moisture. Lost of short flights won't help much. How often is he changing oil. Remember oil temp will trend with CHT however it is very easy to have a very high CHT in a single cylinder with normal oil temps.
