behindpropellers said:
Then again it would be nice if a guy could buy a $15K C-150 and use it as a sport pilot plane. EAA dropped the ball on this one in my opinion.
Considering that the FAA started out with a 900 lb gross weight for LSA, then for a while talked about 1000 lb, and then 1100 lbs, and finally 1232 lbs in the NPRM, I think EAA did a pretty good job by getting the final limit up to 1320 lbs.
You also have to remember that the FAA NEVER considered what type-certificated aircraft did or didn't fit the LSA definition. The rule was never intended to focus on existing TCed aircraft. In fact, the FAA could have just as easily written the rule to exclude TCed aircraft all together. The fact that we have as much opportunity under the rule as we do should be looked at as a victory instead of something to gripe about.
