hunt/trapak88
I have (8) roller tappets/lifters that were removed from my previous cubs 360 C4P when OH. Had 2300 hrs when pulled. I called Aircraft Specialties in OK and they said these can be OH/yellow tagged for $295. New they are $550 per. $100 each. $1200 savings. No need as my case accepts flat tappet.
Also have (6) new SV 72800 roller tappets. Not sure if these are superseded by LRT23381s or not. $100 ea? Make offer.
Also have (8) of the same SV 72800 used. Prop strike. Aircraft Specialties did not know if they could OH them?? But said to send them in and they will see what they could do. Whatever that means. Make offer.
Also have two Roller Camshafts. One that came with the core buy (left) and mine off my previous cub when OH with 2300hrs. Making zero metal and running fine. Had the money to OH so did. Not sure what the “GERMAN” is about but was told it is higher quality material. Which makes sense to me as it’s apparent there is minimal wear compared to the left one, with way more hours under its belt. These are $3k new. I would not hesitate to run this on exp. Your call. Above 23381 tappets ran in sync with this cam. Make offer.
Message if interested.
