Alex Clark
Life Long Alaskan
As a follow up to my previous, and poorly explained, post about my leaking carb on the 12.
It turned out the float decided to be a submarine. See attached photo. So it filled full of fuel and sank.
Thus it was flooding like crazy. So a new float is on order.
I have never seen a semi-clear white float before. It has a Eagle or Hawk face logo.
As I am sure you know. there was a 2009 service bulletin regarding improper floats in Marvel Carbs.
https://msacarbs.com/pdf/SB-2_B_RPLmnt_of_Foam_and_Hollow_Floats_062209.pdf
We also discovered that the primer lines were spraying fuel into the engine compartment every time the primer plunger was pushed. This was adding to the fuel dripping all over the place. So that is the next thing on the list.
NOTE: The IA who installed my new aluminum tanks was not the IA who last tinkered with the carburetor.
