Darrel Starr
Plymouth, MN
ALERT to all Leading Edge users who have original style cowl latches, check your #1 pipe to look for interference!
I just sent the following email to Leading Edge performance@wemakeyoufly.com.
I have a Leading Edge Exhaust on my PA18 Super Cub, N18SY with a 160 hp 0-320, conical mounts. It has the standard PA18-150 cowling and original cowl door latches. The right side forward latch, we discovered, was eating into the #1 exhaust pipe. After 102 hours of use the latch had almost sawed a groove all of the way through the pipe. The wall thickness of the pipe ( at least the end going into the muffler) is 0.048 inches. The depth of the groove was 0.038 inches! Please see the attached picture. Have you heard of this problem before? We will weld the slit shut in the pipe and grind off the latch as much as we can -- do you have any other ideas? I also will post the picture and this description of my experience on Supercub.org so you might want to monitor that site and respond there also.
Darrel Starr
Darrel Starr
