Steve's Aircraft (Brian)
White City, Oregon
Here is Jerry Jacques (Talkeetnaairtaxi) NEW PA-18 just finished in my shop.
List of modifications.
Airframes Inc. airframe with weld on float fittings, metal belly tabs, lumber rack tabs, X brace, upper and lower baggage doors, 180 pound baggage and 3rd seat mod, floor seat belt attach mod, removable cross bar.
Airframes Inc. tailfeathers and rudder.
Airframes Inc. heavy duty struts.
Dakota Cub ribs, spars, leading edge and false spar.
Dakota Cub right wing 24 gallon wing tank.
Dakota Cub spar attach fittings.
Micro VG's
Whipline 2000 LBS gross weight increase.
Atlee Dodge standard length heavy duty gear legs, cabane vee and safety straps.
Atlee Dodge under seat battery tray.
29 inch Gar Aero wheels with double puck brakes, stainless braided lines.
Scott 3200 tailwheel.
Steve's Aircraft master brake cylinders
Kydex interior throughout including baggage side panels and headliner with the exception of the throttle quadrant, rear headliner panel and D window trim. Front kick panels removed.
Floorboards custom cut from .040 alluminum.
Panel custom cut and formed with GPS panel dock and Becker COM. All electrical moved to panel.
Firewall replaced with .020 Titanium. Front brake pedal reinforceing plate (under floorboard) replaced with titanium.
Lightweight starter and alternator.
Steve's Aircraft Gascolator and stainless bracket
All windows replaced with new.
Lower door sheeted with plexiglas.
Airframe was powder coated yellow at Airframes Inc. Engine mount powder coated gray. Gear legs, rudder pedals, brake pedals, and all other miscilanous metal parts and wing parts powder coated black.
Leading Edge exhaust.
Lycon cylinders with Lycon cam and timing gear.
Covered with Polyfiber medium weight fabric. Lemon Yellow and Bahama Blue.
Empty weight on the digital scales......
1100 even, with oil.
Brian.
Micro VG's
Brian.
