From the Aeronautical Information Manual, under Aeronautical Lighting and Other Airport Visual Aids:
"Displaced Threshold. A displaced threshold is a threshold located at a point on the runway other than the designated beginning of the runway. Displacement of a threshold reduces the length of runway available for landings. The portion of runway behind a displaced threshold is available for takeoffs in either direction and landings from the opposite direction. A ten feet wide white threshold bar is located across the width of the runway at the displaced threshold. White arrows are located along the centerline in the area between the beginning of the runway and displaced threshold. White arrow heads are located across the width of the runway just prior to the threshold bar, as shown in FIG 2-3-4."
Tower at PAE finally called me out on having too many “sinkers” on short final and touching down on the grass and rolling up to the pavement. Guess they don’t know how much a set of ABW 31s are these days.
Mikey
Mikey
"Displaced Threshold. A …..The portion of runway behind a displaced threshold is available for takeoffs in either direction and landings from the opposite direction.….."
Isn’t the main purpose of a displaced threshold to maintain ground clearance on a standard 3 degree glide slope approach? (Or the std for that airport?).
….Especially if that displaced threshold is at a towered airport”
Why does that runway have a displaced threshold for landing? You may find the answer here:
https://www.icao.int/NACC/Documents...ACertification2012/ICAOFAACertification15.pdf
The AIM contains normal and recommended operating procedures. Which means that’s the manner in which the FAA expects us to conduct ourselves.
then there’s the catch all regulation: 91.13
I don't know about New Hampshire airport requirements, but in Massachusetts the type of powerplant is not part of the approach obstacle clearance criteria. In fact, the criteria has been in place since prior to the invention of jets. At my airport (28M) we were having an issue with being allowed to cut trees. Mass Aeronautics suggested we paint a displaced threshold line on the runway to comply with the approach and side clearance requirements. This displaced threshold would not apply to take offs. We eventually won the right to clear the trees.I expect that you are correct. However, those standards are for jets. Jets won't be landing on the side grass, which seems to be considered a reasonable thing for appropriate aircraft to do. Not all aircraft are limited to a 3 degree glide slope.
That is another reason. Some of the big airports do that on purpose to help slow an airplane if it overruns the runway. The wheels dig in helping the slowing.I thought part of displaced thresholds had to do with the displaced part not being built as robust as the runway. Big airplanes would eventually tear it up. Not a factor for cubs but they aren't inclined to write in exceptions for cubs in the rulebook.
In my experience, it is lots of taxing and heavy braking turns on asphalt that wear out bushwheels - not landing so much.
What percent of the activities enjoyed by the members of this forum fall outside of the AIM and standard airport requirements? What percent might fall under 91.13 if someone with authority decided that they didn't like you?
I get your point, but I don't think it sticks. I still don't see a regulation that makes it illegal to land before a displaced threshold just as I don't see one that prevents landing on the grass out side the lateral bounds of a runway. I have very limited AK experience, but I understand it is common to land bushwheels before thresholds. On some runways, with some aircraft it is very reasonable and not reckless to land before a threshold.
Why is there a displaced threshold at this airport?I think you know the owner?![]()
