just showing some progress pics of my J-3/L-4/PA-11 custom cub.
1.and now flack for the weight bashers
2.moved elevator bellcrank out of baggage, this opens up the baggage SIGNIFICANTLY.
3.extended the cabin 1 inch more then a super cub...11 inches longer than a J-3 and lighter. this will allow me to stuff an entire 1500 lb dead bear in the baggage.
4.second baggage door for my sluggun. so i can shoot the bear (in self defense of course)
5.rear seat will be fully adjustable and easily removable. front as well.
6.moved the elevator trim outside the cockpit, this gains a half inch in the rear seat width. now i can get that 2,000lb dead moose in the back..... next to the 1500 lb bear.
7.left window will be a full door window with a slide window. because it cool and the stock j-3 window is crap.
8.dual 18 gallon headerless fuel system, so that when i cant hold it anymore and have to land after 2 hrs, at least i wont have to fuel up
9.extra lift handle higher up on left side of fuselage, my back sucks and now and then when your drunck its harde two mooov your cub wit dat stupit low set handler thinger.
10. and harness points. to keep you in your seat dureing a drunken crash, long enough to let the dead bear, moose, guns, and pissed off passenger to all plow you through the firewall
theres more on the list, but i dont have time to sit here and type.
constructive suggestions being taken,
personal opinions ignored (maybe).
