Javron progress.
Nice! I like the fold down aft baggage separation panel. Had to keep hitting pause to 'see' stuff. What is the light above the fuel selector?
Looks good, I am about at the same stage with my Javron build. Quick question, how did you attach the upper baggage door hinge? Mine does not have enough room to drill holes for the screws without drilling into the tubing?
Was that a Ray Allen POS 12 indicator to send flap position into the Dynon?
I have the electric elevator trim and they left out the fairleads to install manual indicator cable. So I was thinking that Ray Allen but it's throw is too short for the jackscrew. I would have to fabricate an adapter that reduced the movement.
If you drill through the channel, you will find .25" clearance between the channel and the tubing. I installed 8 #4 1/4" sheet metal screws to attach the botton hinge. Final install will get a dab of Loctite.20230401_100957.webp
The Ray Allen POS-12 is attached to the flap torque tube and allows flap position to be displayed on the EFIS. More importantly it tells the AOA system the actual flap position. I have used the POS-12 for several other applications on RV's and they can be installed pretty much anywhere with a little imagination. A local hobby shop should have what you need to fabricate the install using clevis's and threaded rod.
Ah thanks.. never thought about the AOA system being more accurate with the flap position input (makes sense of course)..so I need two POS 12's :)
Around 600 hours. Flight controls covered, fuselage & wings this month. Using Oratex 6000, so far so good. Engine all set to be hung once fuselage covered.
Baggage doors a little flimsy, fabricating inner "skins" really stiffens them up.20230403_164328.webp20230403_164316.webp
We were able to cover the fuselage in a long weeken20230425_174544.webpd using Oratex 6000. Sheets were just wide enough to be able to coveqr left and right sides overlapping top a20230425_174558.webpnd bottom.
Thanks KJC. I fit the stabilizer this morning and I will need to trim the lower flange of the inspection cover support about 1/4" to achieve full nose up trim. Good Catch!
20230506_172852.webpMounted engine over the weekend, new YO-360 C1A. Will be mounting a Catto 84X42. Vetterman dual muffler crossover exhaust, Plane Power 40A alternator, Sky-Tec starter.
Are you going to be flying out of Candlelight Farms when you have it finished?
Final assembly will be at OXC, then will go to my hanger in North Creek, NY. I get in and out of Candelight Farm on a regular basis, just a couple of miles from home.
Bought a set online that were the same as Classic Aero used in my RV-7 seats. They come with harness, switches and relays. I mounted the relays behind the vertical support. Each seat protected by a 5a breaker. I think a set of 4 (2seats) was around $60. Don't buy the real cheap ones. E-Z replacement if an element goes bad.
Powered up the avionics today, no surprises. On to the cowling.
Carbon Concepts top Cowling fit without any trimming, very solid.20230805_163235.webp
Looks great! Is that a cowling from Javron or??? Did you make the shark hill vents or buy them somewhere?
