J3, standard SC gear, 850 tires, and on Baumann 1500 Floats most of the time. 90 hp Rolls Royce engine, which is basically a c90 with 9-1 compression, and the Lycon cylinder smoothing.
I've been told a 78-35 Catto is that best climb prop for this. How big of an issue is a 78" prop gong to be for ground clearance? Water Clearance? 76 is probably the safe bet but if I can get a little more bang for the buck, i'll go with the 78.
I have a short prop on presently.
Thoughts?
Zach
Thoughts?
Zach
