info clevis pin aileron
aeroclub
hi
On our Piper L4 from 1944, the aileron attachments are with 7 mm diameter Clevis,
in the catalog I only find 6 mm diameter clevis (1/4).
Do you have any information on this setup?
because it's impossible to find the right Clevis
diameter 7mm
length: 34 mm
thanks in advance
Only metric stuff is the threads on your spark plugs. Nothing else comes to mind. I would replace/repair the blocks and use the correct 1/4 inch pins.
