Husky performance numbers
Yesterday and today, I got to fly formation in a new wing Husky, MT prop, stock gear but no fairings and 31 Bushwheels with my wife in a Carbon Cub on 31's. Husky is 10-15 knots faster. I needed to run back at 16.5-17.5 MP/2250 RPM to stay with her in form.
What was the RPM/MP on the carbon cub when u where doing that?
2320 rpm in the Carbon Cub
How fast is a huskie then on the same 6 gph fuel burn? (assuming the same fuel burn should be about the same power)
Just thinking how much of the speed is the wing vs how much is the constant speed prop?
Just thinking out loud, but depending on altitude 2320 rpm is probably less than 6 GPH?
2300 at 8000 ft; (80 hp - max. continuous) is 4.8 gph according to the CC11-160 AFM available from their website.
MainlandCub is right, it depends on manifold pressure. The AFM he refers to has a chart for % of horsepower at different altitudes. I developed a similar chart but using manifold pressure rather than altitude. And since my plane is EAB (not E-LSA) I don't care about the 80 hp rule.
At 2400 RPM and 18.9" of MP I burn 5.6 gph and at 19.9" it is 6.0 gph. These numbers are from my chart. My earlier post was from memory.
Throttled back to 2000-2100 RPM's and lower manifold pressures the gph flow is in the 3.1 - 4.5 range with ground speeds in the 70's.
And as I indicated earlier that rpm range, depending on altitude, will give me ground speeds in the low 90's mph. And my CC is not a clean Cub with 31's, 3" ext. gear, safety cables, Baby Bush wheel and Dodge long step.
Husky burns less gas than the Carbon Cub at the same speed. Engine management is easier with the Husky's Lycoming, as the CC is more sensitive to mixture, carb ice and high CHT's.
This morning, my wife flew from CNY to BZN (430 nautical miles) in the 180 horse Husky, in 4 hours, 30 minutes, cruising at 8,500 to 11,000 feet, using 31.7 gallons of fuel, landing with 18.3 gallons of reserve fuel.
Kase,
Pull it back to 1900 rpm and 21 inches, and watch the speed and fuel flow.
I tried it and didnt like it. Sounds like the engine is lugging or bogged down. Is there any way to get more cabin heat?
I've been flying a 92 Husky. Indicates 120 mph at 24/2450. Flew next to a Bonanza with a Aspen and at 25/2500 TAS was 137 mph at 4500 msl. 22/2300 indicates 110 mph and 7.5 gph. On 26 in Goodyear tires.
My replica wide body PA-18 with a 180 hp IO-360 on floats will indicate 120 mph at 24"/2450 rpm using a Whirlwind 200G propeller. Airspeed indicator is confirmed accurate. With this knowledge, it seems to me that a PA-18 and a Husky with the same engine and prop are pretty much the same in cruise speed.
Pete,
I have thought for some time that the cowling design also has something to do with the speed of the two aircraft. Consider that the original SC has very large cheek cowl doors, that stick out a long ways. These have to create a good bit of drag. The Husky has no such openings, so that portion of the cowl is a lot cleaner. The WIDE BODY cubs also have much smaller "cheeks", which may contribute to differences in speed.
Or not. :smile::-?
Mike, I always thought it was because the airfoil on the Husky was 'pointy-er' and had less profile drag as a result....I also noted due to
some testing I did that the wing on the cub was the major source of drag....
Airfoils
I thought the airfoils were the same......
Andrew.
It's listed as a 'modified Clark Y/USA 35B' ....The cub airfoil is a 15% USA 35B increased to 15.6%, I read somewhere (in this universe) that the Husky designers took the standard hi-lift airfoil of the cubs and other aircraft(?) and made the nose pointy-er to let it fly a little faster....??
I didn't intend to suggest that the cowling was the only difference that might contribute to a speed difference.....angle of incidence of the wing is clearly a factor as well, and that's PROBABLY what makes up the majority of the difference in speed between the PA-18 and PA 12.
What about the baffling between the super cub and husky? Would this make a difference between the speed of the two?
Mike, how about the twist in the Husky wing? Is it as much as the cub? 2 1/2 degrees?
Pete,
Or not. :smile::-?
Mike,
I don't have any interior in mine. When I place my hands on the inside of the fabric below and ahead of the doors (both sides) I can feel the heat from the engine. Maybe I'm getting a little bit of extra jet thrust from the hot air? :smile:
