Cardiff Kook
Sisters, OR
At what density altitude should you lean the engine prior to takeoff? I have heard 3,000 feet.
My instructor has told me to lean the engine during run-up prior to the run up checks at the prescribed 1800 RPM (PA-18-135.) I have read online the lean should be done at full power prior to takeoff to a point just rich of max power. Which is it?
So with instructor we have done it this way:
1. 1800 RPM
2. Lean to just rich of max performance
3. Perform mag checks, carb heat, etc
I have read from various sources that the lean for take-off should be done at max power.
Do I lean for performance at 1800 RPM then do the run up checks, or do the run up checks at 1800, then max power and lean for performance.
Your input appreciated.
1. 1800 RPM
