Here is the AD. It talks about the fiberglass gear, not the metal at the bottom.
DEPARTMENT OF TRANSPORTATION
Federal Aviation Administration
14 CFR Part 39
Amendment 39-5533; AD 87-04-09
Airworthiness Directives; Helio Model H-700 and H-800 Airplanes
AGENCY: Federal Aviation Administration, DOT
DATES: Effective March 9, 1987.
87-04-09 HELIO: Amendment 39-5533. Applies to Models H-700 and H-800 airplanes (all serial numbers) certificated in any category.
Compliance: Required as indicated, unless already accomplished.
To assure airworthiness of the composite main landing gear legs, accomplish the following:
(a) Within the next 100 hours TIS after the effective date of this AD and each 100 hours TIS thereafter, remove landing gear fairings, if installed, and visually inspect the edges of the composite main landing gear legs for evidence of delamination. Delamination is evidenced by longitudinal splitting between the fiberglass plies. This could occur anywhere along the span of the landing gear leg. If any delamination is found, prior to further flight, install FAA-approved right and left metallic landing gear legs. NOTE: On the effective date of this AD, the only known FAA-approved replacement landing gear is per STC SA2171CE.
(b) If, in between the inspections required in paragraph (a) above, it is observed that the wings do not appear level, or one side of the airplane appears to be drooping, prior to further flight, conduct the inspections and replacement, If necessary, required in paragraph (a) of this AD.
(c) The inspection required in paragraphs (a) and (b) are no longer required when FAA-approved metallic landing gear legs have been installed.
(d) Ferry permits issued in accordance with FAR 21.197 and equivalent methods of compliance with this AD may be used if approved by the Manager, Wichita Aircraft Certification Office, Federal Aviation Administration, 1801 Airport Road, Room 100, Wichita, Kansas 67209; Telephone (316) 946-4400.
All persons affected by this directive may obtain copies of the documents referred to herein upon request to the Federal Aviation Administration, Office of the Regional Counsel, Room 1558, 601 E. 12th Street, Kansas City, Missouri 64106.
This amendment becomes effective on March 9, 1987.
The STC is owned by Sharon K. Brent. When I talked to the FAA, they said that there has been no change of ownership.
STC Number:
SA2171CE
This certificate issued to:
Brent Sharon K
STC Holder's Address:
10 Evergreen Lane
Pittsburg KS 66763
United States
Description of the Type Design Change:
Replacement of fiberglass main landing gear legs with aluminum parts.
Application Date:
08/12/1985
Status:
Reissued, 12/05/2006
Responsible Office:
ACE-115W Wichita Aircraft Certification Office Tel: (316) 946-4100
TC Number -- Make -- Model:
1A8 -- Helio Aircraft LLC -- H-700
1A8 -- Helio Aircraft LLC -- H-800
