wireweinie
FOUNDER
First and foremost, Thank you Stu for your patience and help on this project.
I recently helped work through a problem with a customer, needing help being able to hear his audio system better. Maybe some of you here have already figured it out but for anyone in a similar situation, this is what worked in this case. To start with, the customer has been finding it more and more difficult to understand radio and intercom audio. He does wear hearing aids, so when he asked me about solutions, I started to think about using the aids instead of just making a louder audio signal. I contacted Tao Electronics and asked about their BlueTooth adapters. They make several types of BlueTooth transmitters designed to transmit signals from TVs and stereos, to other equipment such as speaker systems. They assured me that these transmitters will pair with hearing aids designed for that. I ordered one and fabricated an adapter to take the 1/8" stereo plug up to a 1/4" plug. I sent these to the customer and discussed the intended set up. He wore his headset as usual but only plugged in the mic plug to the intercom (the smaller diameter plug). Instead of plugging in the head phones plug, he plugged the BlueTooth adapter to his intercom. The idea being to talk normally through the mic but to actually hear the audio through the hearing aids which should be paired with the adapter. Initially this did not work, but the customer kept working the issue with the hearing aid manufacturer. Come to find out certain brands will or will not pair well with certain equipment. All it took was a different model of hearing aid and they paired with the BlueTooth adapter. Once paired, the system worked as we had intended. The customer does not have to remove his hearing aids, as some do, and he can use his regular headset. This allows noise reduction from the ear cups (which should help with volume) and allows normal use of the microphone on the headset. The only 'special equipment' is the BlueTooth adapter.
There are different brands and models of these adapters, so look around for a style which will work for you. We used a smaller, battery powered one for portability. Before you make a purchase, I'd recommend talking with the hearing aid manufacturer and telling them what you intend. My customer was able to get the best info from them, that led to getting his setup functioning.
Hope this helps someone out there!
