GTP 59 OAT Probe position
Under the removable wing root fairing on the left side - towards the rear if your left window is a swing up piece? This is where I saw most of the experimental installs at Oshkosh the other year. 1746774504209.webp
I fabricated an inspection cover between 2 mid-wing ribs, and mounted the magnetometer and OAT probe.20240106_164843.webp20240106_164834.webp
