GPS Antennas and Garmin Avionics
Lotro
MEMBER
Hey Folks,
I've been lurking for a while, just came up across this problem and thought I'd crowd source.
Background:
I'm doing a total restoration of a 1951 Super Cub that belongs to my father. The work is being completed here in Canada by a reputable aviation mechanic who has done a handful of fantastic similar restorations and I'm working alongside him as a shop helper and learning as much as I can as we go. The completed aircraft will be a certified super cub.
Avionics:
We've purchased some newer avionics, and have received some hand me downs which means the final aircraft will have the following:
GTX335 - XPDR with GPS (ADSB Out compliant)
GTR225 - COM
Garmin G5 - EFIS - this is meant to be used as an Artificial Horizon and is of particular interest because it doesn't require a vacuum system.
Garmin Aera 796 - Portable GPS, panel mounted with an AirGizmo
Garmin GDL 39-3D - Provides ADSB-In services
Here's the thing: The GTX335 requires an external mounted GPS antenna, and the G5 requires an external mounted GPS antenna. Ideally, I think I'd like to have the GDL 39 and Aera 796 connected to an external GPS antenna and so, it seems dumb to me that I'd need 3 externally mounted GPS antennas to power this stuff.
Any thoughts?
~Lotro
The GTX 335 has three RS232 outputs that can supply GPS info to other devices. Mine supplies it to the G5, the MVP-50, and the ELT. One antenna.
Super helpful. Thanks so much! Are the wiring diagrams available in the installation manual (which I have)?
it can be intimidating.
if the RS232 data types are the same, you can, and should parallel them from one port. some Garmin products force all of the same data types to be output from the same port. PM me if you need help.
there is also 429 and others in some cases
tin tưởng.# tai nạn liên lạc mới nhất bữa nay 10/10/2018
I. Những chốc lát ảnh tin cáº*y đẹp nhất năm 2017
Khi tin tưởng nÃ*y được truyền ra ngay tức thì trở thÃ*nh đề tÃ*i bÃ*n tán sôi nổi ở Trung Quốc lẫn HÃ*n Quốc. Blogger cho biết: "Vừa nháº*n được tin tức rằng Phạm Băng Băng không trốn thuế, cô cÅ©ng Ä‘ang chuẩn bị quay trở lại công chúng". Sau vụ việc, cảnh sát nhắc nhở người dân: “. Sau khi Weibo của Sina đăng tải lại thông tin nÃ*y, bÃ*i đăng đã nháº*n được số lượng bình luáº*n khổng lồ lên tá»›i 16 ngÃ*n comment, rất nhiều trong số đó mô tả sá»± bất bình vÃ* chỉ trÃ*ch: "Không còn sÄ© diện nữa hay sao", "Biết mình phạm tá»™i còn không biết hổ thẹn, tháº*t đáng sợ", "Hãy nhá»› mÃ* đối tốt vá»›i fan, bởi chỉ có họ hiện nay má»›i cho cô tiền thôi", "Vẫn còn định kiếm tiền từ nghiệp diá»…n cÆ¡ đấy", "Da mặt dÃ*y mÃ*y dạn tháº*t",.
Nghiên cứu được thá»±c hÃ*nh bởi má»™t nhóm các nhÃ* nghiên cứu ở Ấn Độ, nÆ¡i có ca tá»* dong liên tưởng đến selfie hÆ¡n bất kỳ nhÃ* nÆ°á»›c nÃ*o khác. ChÆ°a rõ tại sao quân Ä‘á»™i Đan Mạch lại “thiếu thời gian” khi Na Uy đã thống nhất về cuá»™c táº*p tráº*n từ đầu năm 2015. Điểm nÃ*y cố tình tạo Ä‘iều kiện để bến xe Ä‘á»™c quyền, gây khó khăn cho doanh nghiệp, quay trở lại tình trạng cách đây 15 năm “thủ kho to hÆ¡n thủ trưởng”. Tôi lá»›n lên trong má»™t gia đình nhÃ*ng nhÃ*ng, không nhiều tiền nong, nhÆ°ng có má»™t tuổi thÆ¡ tÆ°Æ¡ng đối êm đềm dịu ngọt. Việc gì cần lÃ*m thì phải lÃ*m ngay, nhất lÃ* những việc mẫn cảm, liên quan đến đời sống của người dân. Ngôi đền ẩn mình dÆ°á»›i những tán cây ráº*m rạp, nhìn ra sông Hồng cuồn cuá»™n chảy mÃ* nhá»› rằng Công chúa Ngọc Hân đã từng viết những dòng thÆ¡ đầy yêu để Ä‘Æ°a tiá»…n chồng lÃ* HoÃ*ng đế Quang Trung về nÆ¡i suối vÃ*ng.
II. tin cẩn giáo dục 24: HÃ*ng loạt biển trường Ä‘á»™t được che bịt; NXB Giáo dục nói gì trÆ°á»›c khoản lá»— 40 tỉ má»—i năm?
sẽ bất ngờ xuất hiện cùng vá»›i nhiều tin vui nhÆ° năm trÆ°á»›c hay không? Nữ hoÃ*ng sẽ lại tỏa sáng tại thảm đỏ quốc tế vÃ* bá»™ phim truyền hình. thời khắc nÃ*y nÆ°á»›c lÅ© ngÃ*y má»™t dâng cao. Ngồi thẳng, duy trì giao thiệp bằng mắt vÃ* giảm thiểu việc dùng các từ phụ trình bÃ*y rằng bạn biết cách giao du tá»± tin vÃ* chuyên nghiệp. Từ thời trung học, ChÆ°Æ¡ng Trạch Thiên đã từ khÆ°á»›c đóng Kim lăng tháº*p tam thoa của đạo diá»…n TrÆ°Æ¡ng Nghệ MÆ°u vì muốn há»™i tụ học hÃ*nh. Má»™t trong số các nghi phạm được xác định danh tÃ*nh lÃ* Maher Abdulaziz Mutreb - cáº*n vệ thân tÃ*n của Thái tá»* Mohammed bin Salman. hiện thời, khi nhắc lại, đó nhÆ° lÃ* câu chuyện cổ tÃ*ch, về cô nÃ*ng đăng lăng loÃ*n lên mạng rồi tạo thÃ*nh “cÆ¡n bão” cuốn mọi người vÃ*o đó.
Hải Yên - Xuân Cường/Báo tin. Theo đó, vá»›i VCK Giải Vô địch Bóng đá Đông Nam Á 2018, AFC U19 Championship vÃ* AFC Asian Cup 2019, VTV được cấp phép quyền sản xuất, khai khẩn, sá»* dụng Ä‘á»™c quyền trên kênh Truyền hình Mặt đất miá»…n phÃ* của ĐÃ*i THVN vÃ* tiếp phát vẹn nguyên tÃ*n hiệu kênh chÆ°Æ¡ng trình trên Cáp, Vệ tinh, IPTV, Internet vÃ* Di Ä‘á»™ng (không bao gồm trên Mạng tầng lá»›p); Quyền không Ä‘á»™c quyền khẩn hoang tÆ° liệu để sản xuất chÆ°Æ¡ng trình bên lề vÃ* tin cáº*y; Không được quyền cấp lại quyền cho Ä‘Æ¡n vị thứ ba. Phát ngôn trên được Ä‘Æ°a ra không lâu sau khi Tổng thống Donald Trump xác nháº*n Đại sứ Mỹ Nikki Haley tại liên hiệp quốc đã từ chức vÃ* sẽ rời cÆ°Æ¡ng vị cuối năm 2018. vÃ* E’Dawn bị đánh giá lÃ* Ä‘i ngược lại vá»›i chÃ*nh sách của công ty.Để tạo dá»±ng vị trÃ* của Senta, chị Thy đã tìm ra sá»± khác biệt cho thÆ°Æ¡ng hiệu của mình. Điều mÃ* má»™t số nÆ°á»›c lo ngại lÃ* Trung Quốc sẽ sá»* dụng Interpol để bắt giữ các tham quan mÃ* bất chấp luáº*t pháp sở tại.
III. tin giải trÃ* ấn tượng ngÃ*y 13/10: Bảo Thy tung ảnh gợi cảm, bác tin đồn giải nghệ
Bạn có thể tìm má»™t gu má»›i, tìm má»™t công việc má»›i, đọc tin tưởng hay giao thông vá»›i người tình. Chứ trÆ°á»›c kia khi xảy ra vụ việc, Ä‘á»™i nghiệp vụ Công an huyện Ä‘i gần 20km đến thì vụ việc đã xong rồi, kể cả trong vấn đề thu tháº*p tin tưởng sẽ khó khăn hÆ¡n”- ông LÆ°Æ¡ng Mạnh Tường nhấn mạnh. Do đó Ä‘Ã*ch dÃ*i hạn cần phải tạo bản web đáp ứng về giao diện cho các thiết bị tạo ra má»™t trải nghiệm người dùng liên tục vÃ* nhất quán trên các thiết bị. Má»—i người má»™t kiểu, người thÃ*ch món nÃ*y hÆ¡n món khác, người thÃ*ch vÃ*i món, những anh chị mê cả bốn món thường vÃ*o tù rất sá»›m. HCM giữa mùa giải 2016 vÃ* đổi tên thÃ*nh CLB SÃ*i Gòn. Theo thông báo từ Bá»™ Y tế, qua thÆ°a nhanh của Bệnh viện E vÃ* qua tin cẩn trên các công cụ thông tin đại chúng, từ đêm qua 16/9, Bệnh viện E đã tiếp thụ cấp cứu 8 người bị nạn từ Đại Nhạc há»™i công viên nÆ°á»›c Hồ Tây chuyển đến, trong số nÃ*y 5 người bệnh đã tá»* vong.
Ông Wang Huiyao, giám đốc Trung tâm Trung Quốc vÃ* ToÃ*n cầu, đánh giá: “Điều đáng lo âu nhất lÃ* khả năng Mỹ vÃ* các đồng minh bắt tay hình thÃ*nh rÃ*o cản thÆ°Æ¡ng nghiệp khiến Bắc Kinh khó tiếp cáº*n vá»›i thị trường. Trong số nÃ*y 5 người bệnh đã tá»* vong. Nếu tòa án đã yêu cầu đến lần thứ hai mÃ* thân nhân của chồng bạn vẫn không chịu cung cấp địa chỉ, tin tưởng của chồng bạn cÅ©ng nhÆ° chÆ¡i chịu thá»±c hÃ*nh đề nghị của tòa án thông báo cho bị Ä‘Æ¡n biết, tòa án Ä‘Æ°a vụ án ra xét xá»* vắng mặt bị Ä‘Æ¡n theo thủ tục chung. Những nhÃ* sáng láº*p của váº*n dụng phát thanh tin cẩn báo chÃ* NOA cho biết họ tá»± tÃ*n Ä‘ang Ä‘i đúng hÆ°á»›ng vÃ* trong mai sau, startup có thể còn được phát triển vÃ* mở rá»™ng ra nữa. Phong cho biết trÆ°á»›c kỳ thi THPT quốc gia, cáº*u thi trượt học trò giỏi tỉnh môn Lịch sá»*. Đây sẽ lÃ* các tÃ*n hiệu hăng hái giúp lôi cuốn dòng tiền quay trở lại vÃ* các chỉ số thị trường được kì vọng sẽ bình phục.
Gesundheit
Hey Folks,
Background:
Avionics:
GTR225 - COM
Any thoughts?
~Lotro
Pretty much any Garmin unit will communicate with any other Garmin unit by RS 232. And most other brands made in the last ten years or so will work well with each other on RS 232 data lines with a little programing on start up.
Other types of data lines such as ARINC 429 or 422 are generally used to control indicators or remote units.
In your case, if you have the GTX 335 with internal WAAS GPS source (verify that!) you can just use it as the GPS source for your G5. Then connect your GDL 39 to your 796 with the patch cord. The internal GPS antenna in the 796 works fine in most aircraft. That way you'll only mount one external GPS antenna.
There's an airplane on my home field that has what looks like two or maybe even 3 GPS antennae.
I'm thinking GPS, ADS-B, and 406 ELT?
When I installled a G5 the manual called out a Garmin (external) antenna, can't recall the model.
They're spendy, so I read the manual again & it said any antenna meeting a certain performance spec.
I found a Garmin antenna that did so, usually used with handheld GPS's, it lays on the top of my glareshield.
As I recall, it cost me $24 from gpscity.com.
FWIW my G5 is not one of the STC'd ones, it's a pre-STC version installed under the FAA "electronic horizon" policy statement.
