James L. Smith
Western NC
I'm trying to figure out how best to do this without dinging up the trailing edge purchased from Dakota Cub. The TE comes in two strips with screws holding it together in a sort of V-shape rotated ccw 90 deg, with two flanges folded over the V, closing it, and making it into a box. The 90 deg. flanges folded over the V are then screwed together with no. 4 by 1/4" screws-- in the forwardmost section of the TE when installed.
So, to install it on the wing, you've got to cut out slots in the V for fastening to the trailing edges of the ribs. N271T doesn't have flaps.
Anybody got any suggestions on how best to do this? Aviation snips, die grinder, band saw? Each method has its drawbacks in my experience.
We don't have a milling machine.
The die grinder works well for cutting excess length off the false spars.
And then I'm a stickler for deburring and round-filing a radius where a crack could start.
You should see the trailing edge being replaced if you want to witness a JB-welded mess full of cracks and decades of abuse.
