Would anyone have some suggestions as to where my electrical man would find some specifications on this T&B circuit breaker? It reads as a Klixon CA 2.
It lives on top of the glovebox.
What's everybody's favourite 850 tyres?
On a long cross country I once read in my POH to "apply brakes before engaging parking brake" could be the issue.Never have used mine so I’m sitting in the plane to try it. Turn the lever and pull, I have a pretty good tug to get one click.
Hi guys.
I'm looking to purchase a set of 850 x 6 tyres. All right tires for you lot. Looking on A/Spruce I see the Goodyear are tubeless. I seem to remember the one's I had on the Cub had tubes.
And while I'm in that general area the clear leading edge tap on the gear leg is in poor condition. Any do's or don'ts with the gear tape?
I doubt I have anything to fix.
Can someone post a close up picture of the parking brake cable attached to the master brake cylinder on the brake pedals? Mine is missing/inop, and I'd like to piece together the parts to make it work again, and the IPC picture really isn't that clear. What's it supposed to look like on a '55?
I can send you a picture of the one I installed on mine, tomorrow. I wouldn’t install the early model PB. Go with the late model install. The early model system is hazardous to your health. Mine is a 1955.
Same here- I deleted mine after looking at how the mechanism ties into the normal braking. It is a recipe for disaster on the early models
Do I have to also install the late model pedals? I don’t see away to attach cables to the brake pedals on the early brakes - rounded style. Where did you guys source the parking brake bell crank assembly?
