On Patrol
BENEFACTOR
Wentworth NH" The WAD" NH96
Steve always complains that folks will call him with a problem and after several suggestions they never call him back to let him know what the outcome was. He says this would really help the next guy.
Had an issue this winter where the tach started to flutter one cold flight and went to 0, The noise in the front let me know that it was the tach problem. Same flight the 496 also lost it's mind and could not find sattelites so I decided to come back to the barn and call it a day before something fell off.
Tach was replaced 600 hours ago and every so often it fluttered at high rpms. Pierce told me to take a look and possibly lubricate the cable. You can pull out the drive cable and what I found was rust and very dry. The spline on the engine side was worn down or sheared down. I got a new cable from Spruce and replaced it yesterday. The square end on the tach side was a workout to get into the tach which is high on my panel upper throttle side. I eventually pulled the tach connected it and reinstalled with the cable on. A second person might have been able to manipulate the drive but I was solo. Anyone with a trick I am all ears for the next time. Also cable is 4 inches longer than what it should be and probably part of the problem. New shorter cable at overhaul is on the list
Garmin 496 I have had it since my trip to Idaho about 6 years ago and what I finally realized was the date and time was not right. I corrected both but within a shorth preriod it would lose time. Also the data was 6 years old. So after spending a fortune updating the data $399 I purchased a new battery for $38 and she is good to go.
So Steve, Thanks for the help and this is what I found for your memory banks!!
