Iam a newbie, don't know much about this
thread stuff but here goes. Can someone tell me
the year of my cub by its serial #? Mine is a
135hp, serial # 18-946 Thks Cliffy
And if this is lost, you can order the CD of your aircraft records from the FAA. Then just print out your original on your printer. It will be on the CD. It's a wonder that any of these "operations limitations" forms have survived all these years. Even though the weight and balance portion may have been superseded the rest of the form is still valid and is a "MUST CARRY" item in the airplane.FWIW I believe what is required to be on board the airplane is the "operating limitations".
All the operating limitations may or may not be in an owner's manual.
Most older airplanes have a one or two page "approved flight manual" or "airplane flight manual" with all the required information.
Usually these were factory issued right along with the W&B sheet, both with the airplane's tail number typed on, so they are aircraft specific. If you don't have one, hopefully you can scrounge a photocopy of one from another airplane of same make & model, and doctor it up with your own tail number.
I know I'm replying to an old thread but do you still have a copy of the Flight Manual sheets for a Pa-18 125? ThanksYou need to get someone with the same model as you to copy and send you the pages. I have ones for the PA-18-150, PA18A-150 and PA-18-125.
But I think you have the military 105 special, so it would be different.
