I’m no mechanic and no expert. There are many on this site that do this sort of repair for a living and are better equipt than I to give advice.
if You need more down trim you will need to lower the aft end of the horizontals. That can be done by grinding out the tail post tube and bending the upper longerons downward. Then weld in a new tail post tube. Currently 145$ from univair. While not the proper fix you could instead cut off the bracket that has the bushing for the aft horizontal cross link tube and cut some off the bottom and reweld it on.
How much to change shouldn't be a guess but calculated. My cub drawings didn’t show the tail angle in relationship to the wing. If you can’t find that angle on the drawings you might get it off a good cub. All this is assuming your experimental is built according to cub Supercub specs.
If you are trying to land this cub short and fly it slow on landing its an accident looking for a place to happen. Good luck with this.
Shorten the bottom longerons 32" ahead of the tail post. Calculate and cut out the appropriate amount, make an outside sleeve repair. Nothing else will be effected. Done.I’m no mechanic and no expert. There are many on this site that do this sort of repair for a living and are better equipt than I to give advice.
Adam,
The butt rib and fw can be difficult to measure and by the time you get to the tail they can be way off. That is why I suggested earlier to make it simple and just measure the relationship between the wing and nose down trim. The longeron should be straight. It is bent upwards which will lose your nose down authority. You said some work was already done in the tail but not what was done. This simple measurement could show you if there is a problem. Just measure off the bottom of the cleaned spar caps under the wng root fairing and and the stabilizer in the up position. Not trying to make a bunch of work for you but it might be a telling measurement.
I used the words could and might in this post because you just never know. You asked so that's all I have. If this doesn't help I am back to lurking lol. Good luck
I’m concerned that the focus of this thread seems to be how to get even more positive lift on the stab instead of finding out WHY the tail has positive lift on it at all........when it shouldn’t have ANY.
