mike mcs repair
I can measure this weekend. Set plane to level flight and then measure at the root across the spars?
bottom of butt rib, but same...
Do you start thinking about when your chute was last packed after 6 1/2 turns?Micro vg’s reduced my spin recovery from seven turns to about one third of a turn....
Could you please clarify "positive number greater than the wing number"? Which direction is "positive", and in reference to what? The Horiz Ref Line? or ? Thank you!Measure your wing angle across the bottom of the spars, then put your trim full flight nose down trim. Measure the stabilizer angle. You should have a positive number greater than the wing number. This will give you an idea of the trim relationship to your wing. I would do both wings
Before you start adding slats or VGs or ........ fix your issues. IF adding other "enhancements" "cures" the problem, they are only masking the real issue. Band aids only cover the wound, they don't fix it.I've thought about it but I thought that would intensify the problem wanted to increase the lift moreso….Never flown a slatted cub so school me up..
If your plane could not recover from a spin in no more than one turn, something is very wrong. That is the certification requirement. The VGs are only a band aid covering up the real issue.Micro vg’s reduced my spin recovery from seven turns to about one third of a turn....
Have you thought about installing a bungee on the trim system. You can increase the ratio by increasing the spring tension spec. as required until you reach perfection. easy fix i would think.
It would help to know what your baseline is now. Put the cub in level flight as you would for rigging and get the wing angle at the fuselage and you tail travel up and down.
It would have made a lot more sense had you measured with respect to the bottom of the door frame.....by nose up do you mean the nose of the stab or the nose of the aircraft?
First glance it looks fine. Fobjob, put a plus in front of the nose down and a negative in front of nose up to realize these numbers are on either side of the firewall 90 to get the 6.5 range I believe? Buy the way,nose down trim should be called stab up as in tcds. No big deal. That is just the way it is supposed to be referred to, to prevent confusion although doesn't always. Measured movement is the direction of travel of the control surface
Thanks Mark, the low angle of incidence of the wing appears to be the major culprit, the lack of pitching moment will require up force on the tail, which is BAD.... unstable .. stall/spin hazard...the twist in the wing tips might be excessive also, effectively lowering the pitching moment. If I had an experimental cub, I would make the twist in the wings zero and put some aluminum angle iron on the inboard leading edge to control the stall.
All this is assuming that the firewall is actually ninety degrees to the waterline....
Any measures applied to the tail isn’t going to solve the main problem.....
