exhaust
Mark,
I'm running a 160, stock B2B with standard (legal) compression pistons and no porting or flowing (the Lycon mods). When Lycon tested the system, they first tested it on a modified 160 (10:1 compression) and it only got 5-6 hp. I'm thinking LE has the exhaust tuned to eliminate backpressure, and the higher compression pistons create more backpressure that the LE system is not designed to eliminate. Those pistons are not legal for certified cubs anyway, and I like the 12-13 hp addition.
Unfortunately, I don't have any good numbers per your request. With spring here I just took the plate off my oil cooler, and my feeling right now is that the oil temp is going to run about the same. The other thing is I just came out of a 2 yr. rebuild, and the new engine baffling cooled me off about 15-20 degrees (!), so I don't have a good base to go from. I'm actually having trouble right now getting it up to 180 degrees, but when the oat gets to 50 or better it will get there.
I don't have cyl. head gauge, so can't help you there. After running the airplane the exhaust itself seems quite hot, but cools down quickly. My heat robber is currently disconnected, but I haven't noticed too much heat through my regular heater. I, too, have had to stuff a rag in the hose in the summer because of leakage through the regular heater valve with the stock exhaust. Too much heat is rarely a problem here in Idaho, especially when you're hunting coyotes!
I also just installed a fuel computer (after the exhaust) so am only now getting accurate fuel flows. Until I do some long trips for comparison I won't know for sure, but my guess right now is no increase, which surprises me a little. I'm indicating 7.5 gph at 2600 rpm at 5000' at 25 degrees rich now. I flight planned the old exhaust for 7.5 gph also.
I believe I'll end up with a higher pitch prop after more testing, as I'm getting more rpm than I need and want to bite the air better. This is a new concept for me, as I've always gone for rpm. However, recently we've been finding the airplanes are performing much better at a more optimum pitch (usually higher) because the prop is more efficient (i.e. biting more thin air). We are finding this particular true with experimental 180 cubs with the long (84") props.
By the way, visit Amazon.com for the video Mountain Flying with Dick Williams!
Dick
