Captain Ron
PATRON
Les Cedres, QC, Canada
Edit: Dang - of course I missed the spelling error in the thread title before posting. I guess we can't fix those later. Valve Leak!
Hello All,
I need some input from vast bank of knowledge here!
Experimental PA-18, O-290D2B, 260TTSO. For the past 10 years compressions have been solid at 75 +/- 2 on all four cylinders. Last year (June 2020) number 3 went down to 72. I thought ok, lower but only 1 psi out of normal variation, couldn't hear a leak and borescope looked fine. Fast (slow?) forward to this year (25 hours of flying) and compression on number 3 is down to 70 with noticeable leak through the exhaust. I flew it again today for an hour and re-did the compression test and got 60. Staked it a couple times with no change. Had a much closer borescope look (by the way - make sure you read the temperature restrictions on your scope - nearly cooked it) and still seems normal. Tested compression again after borescope and when cooler and got 64. Otherwise the engine is running well, oil consumption is stable at around 8 hours per quart, doesn't lack power, runs smoothly, isn't making metal and oil analysis is normal (have not received this years results yet though).
I'm certainly no expert in reading borescope images so I'd appreciate some opinions on the photos. The glare from the LEDs is a bit annoying but to my eye the complete valve face looks uniform with no asymmetry. Here's probably the best one:
So what's next? The compression trend has me worried but the borescope doesn't appear to indicate imminent failure. Fly another say 5 hours and check again? Find a local mechanic and get a wobble test done? I've read about some success with lapping with the cylinder in place - is that worth a try? Or just pull the cylinder (*shudder*)?
Appreciate the help!
Cheers,
Jeff
Hello All,
Cheers,
Jeff
