I have been reading these post and it seems everyone is interested in hrsp gain by numbers i.e. 13 etc. Actually guys, none of the exhaust mods will make your engine produce more hrsp., such as 150 to 163 for instance. A Lycoming engine is rated at 150 hrsp at a specific rpm and manifold pressure, and with a fixed pitch you can possibly change the rpm, but not the manifold pressure. This relates to another term "torque". What the exhaust systems mod does is decreases the back pressure, allowing the manifold pressure to increase therfore increasing the available " torque", not hrsp. This means when you haul back on the stick and point the cubs nose up you can maintain the rpm at a higher angle of attack because you have more available, useful torque to hold it there. I messed around with my cubs exhaust back in the 70's and gained 200 rpm static. That is a lot of gain of lost hrsp/torque over the stock system, and the cub flew like it, however the FAA at the time wasn't too interested in helping out, so I dropped it.
Steve
