Sooooo, I had an issue a few weeks back with a 400 Rpm drop on my Right mag. Pulled/cleaned/tested the plugs all good harness looked fine, timing was off about 15 degrees so figured I had an issue with the points. So pulled the Mag and sure enough the plastic block that rides on the cam had been melted on the point side of the block, little bit of pitting on the points but not bad. Figured might have a bad condenser. Called my mag guy and he agreed, so new points and condenser went in and problem solved. 3 hours of flight time latter and now total loss of Right mag. Also really did not want to turn over, it did that just about spin but stop thing, 5-6 times then she went over the top and started. Now I have been having some issues with intermittent starter performance. I replaced the 10 year old battery this spring and 3 years ago I did the bottom end because of a bad cam, put new cable from battery to starter and made sure the ground strap to the motor mount was clean and tight. I check it closely at annual every year. So now pull the mag and same problem melted plastic block. Called the mag shop and said I had the same problem They said "You know we saw that once a few years back with a new set of mags we sent out, the plane had a bad engine ground". Now I know my ground was good because I put it on myself!! But I am standing right next to the plane so while still on the phone I reach up and give it a feel
. Sure enough engine mount side was loose. Looks like when I used the mount to lift the front of the plane with engine hoist to put my ski brackets on I bent the tab over and bolt was not as tight as it should be. The two give away keys is the poor starter performance and the Right mag was the only one with melted point cam follower. Just for fun who can say why it was just Right and not Left mag with the problem. Web you have to wait and give the others a chance.
