mvivion
FOUNDER
Okay, this is a modified Cessna 175, converted to tailwheel, with an Avcon engine installation of an Lycoming O-360 A1A, constant speed prop. A JPI 900 engine analyzer is installed.
This engine's cylinders have always run pretty hot, but it seems to be getting worse. Enroute across Montana last weekend, CHTs were running 410 to 415, except for number 3 which runs a bit cooler. That is leaned till it pops, then richened considerably, at 2350 rpm and 20 to 21 inches of MP, and 9.7 to 9.8 gallons per hour. In my experience with these engines, that's a pretty conservative fuel flow for that power setting.
I've done a good bit of work on baffle seals, and they're pretty tight now. Looking into the top deck with a flashlight on the ground, they pretty much show few if any leaks, certainly no significant ones.
I spoke to a good friend who flys a lot of these engines, and noted that in his experience, the JPI instruments read about 20 degrees high on average. If that's true (and next time I fly we're going to check those temps with an IR gun), that would imply CHTs are below 400.
I've flown a lot of 360s, including several on AvCon converted Cessnas, and never seen these high temps. Interestingly, these temps are pretty consistent as well, as in regularly, and consistent between cylinders.
And, summer temperatures aren't even above 80 yet....
Any thoughts on where we should look?
