Electronic Tach
Sikorsky
I’m sure this has been discussed before but I can’t find… I just got a new prop from Sensenich. Very pleased thus far, but want to double check tach accuracy. Laser? Spark plug sensing? What should I use?
Zach
Tru Tach. Some guys will suggest cheap hobby store optical tachs. I fell for it. Waste of time and money.
Zach
What type of lighting do you have at your airport? If it is of the mercury vapor type (perhaps other types will work as well), face the plane towards the light (at night) run the engine at various rpms and watch the blades. When on a multiple of 60 (60hz) the blade will remain still. When not on that multiple the blades will appear to move backwards or forward. So, running it at 600, 1200, 1800, 2400 the blade will be still. Compare that to your tach reading. If the tach agrees, it's accurate. If it doesn't, make note of the difference. With a two blade prop, 600, 900, 1200 etc.
Tru Tach. I have yet to see a mech tach that was accurate. Mine was off 250 RPM on the top end, others I have done were 150-250 RPM off (mech tach reading high). If you have an engine analyzer picking up off a crank sensor or the mag they are accurate.
I thought the tach was off in my 185 so I installed a Horizon electronic tach leaving the mechanical tach in place. Running both tachs for a while, they were in total agreement with each other.
I guess I was referring to the piper tachs. It's pretty rare from the 15 or so that we have tested when playing with the prop pitches that the piper tachs are even close.
What is the best/simplest electronic replacement tach for the supercub?
certified or non
certified or non
Electronics International. Power & ground wires and two sensing leads that connect to the key switch. Then remove the drive cable and throw it away.
We had a Tru Tach and my $20 RC tach side by side on a few different aircraft. Within 40 rpm of each other, on one plane it flipped who was high and who was low.
This UMA tach is a 'digital' tach with a needle, and comes with an electric sender that screws into the tach drive, eliminating the coax. You can order it pre-marked with a 2700 redline.
It's worked well for me, and I prefer needles to fussy digits.
https://www.aircraftspruce.com/catal...clickkey=10133
I have owned several of the UMA tachs. On the O-320 on my SC clone, I couldn't get the transducer to clear the angle oil filter adapter. I sent it back to have the tach adapted for a magneto transducer that fits into the Slick mag. Simple transducer that screws into the side of an existing hole in the mag and picks up the magnet passing by, so works whether you are running on that mag or not and is accurate. (count had to be changed on the tach as the tach drive transducer provides 4 pulses per revolution while the magneto pickup provides 2 pulses per revolution) They also have the same kit for the Bendix mags as well. If you have an analog panel and like an analog tach, that's my go to tach. It comes with the face marked for Continental or Lycoming, or they will paint one to your specs.
-Cub Builder
I have to admit I've used a $20 hobby tacho for drones and it's been excellent, tests spot on with it aimed at the hangar lights
As a pirep, I borrowed an electronic tach checker from a friend. At 2500 rpm the electronic tach read 2491. Pretty darn accurate, much more so than what I was expecting.
Zach
