CubDriver218
Minnesota
Richard, you are worrying too much. Just use the -12 gear with a -18 upper front fitting. I have Citabria 7GCBC gear on my -18 clone and it works just fine. I just lengthened the fitting for the rear strut. The only difference with those two -12 gears is that the float step will be about 1/8" difference in it location.
So are you saying my best bet is to purchase floats off a stock PA-12 and figure it out from there?
I do have the opportunity to buy some edo 2000s locally that came off of a PA-14. Does anyone know if these will work? I'm waiting for the guy to send me measurements.
I'm told the "fish mouth" (the angle between the top of the floats and the bottom of the wing?) needs to be correct for the plane to perform well on floats. You need the angle of attack.
