Eddie Foy
South Florida
Since I am having my engine overhauled, I decided to do a few things while Miss P was down.
I love my plane but hated the panel. It also had a pedestal between your legs that I really didnt like. I decided to put in a new panel, stainless firewall, and a three piece boot cowl.
I have read Bill Rusks Javron Cub thread twenty-seven times. I also lean on Steve Pierce for parts and advice. I am working under the supervision of a buddy IA on my field. I consult with him and others, do the work, and he inspects it and suggests any necessary changes.
I removed all the vacuum stuff like the pump, AI, and DG. It also had a VOR that went in the sell pile.
I am going back with Trig radio and Xpdr and EI CGR-30P. I will use my Ipad mini and Stratus 2 also. My panel will look very much like Kirby's.
So far, I have built a new battery platform in the tail. I nutplated everything so it can be removed if necessary without having to hold nuts from the bottom therefore requiring two people.
The Atlee Dodge extended baggage is going in too.
I am also changing from the glass fuses and two leads to the wing root to a master Contactor. I am removing the electrics like the master and ammeter from the wing root.
I have my three piece boot cowl about 2/3rds built and am stringing new wire from the battery section forward. Most all of the wiring that I can access is being replaced.
My goal is a simple panel with backup attitude info from the Stratus 2.
I will add more pics as I go.
Welcome to my rat's nest!!
I stopped removing stuff about here.
Boot Cowl Coming Together
Clyde's Stainless Firewall and Blank Panel
To Be Continued.......
