aviationinfo
Southwest WA
Hi All:
Was off having a great time in Idaho visiting strips when I noticed a nice dent in my horizontal stab, apparently from a rock thrown by one of the tires.
The dent is a bit smaller than the size of a quarter, indented nearly 1/4" at it's deepest point. The fabric was torn (right through the protective tape on the leading edge).
I had my IA look at it. We cleaned off the fabric to allow a good look---there is no cracking of the 4130 anywhere. He feels the dent isn't worth anything more than a cosmetic repair, certainly not replacing the leading edge of the stab.
A friend looked up dent repair in AC 43.13 and discovered that if the dent in a tubular structure is larger in size than 10% of the diameter of the tube, you're supposed to splice in a new piece. So are we to believe basically that something smaller than a BB-sized impingement on something like that requires a splice? That seems silly to me. My understanding of 43.13 is that it is not regulatory in nature but of course someday the plane will be sold and obviously the repair should make sense.
I need advice on the dent. It seems ridiculous to replace the leading edge of the stab over a dent, UNLESS of course it's compromising the safety/integrity of the structure. I cannot believe you folks landing on gravel bars don't have any dented stabs, or haven't repaired same. How do I handle this?
Thanks in advance for your thoughts.
