Binty
South Island, New Zealand
Iv spent some hours trawling the forums about this topic and there is some conjecture on the setup... I need some definitive answers but first I will share what I know and have found; (Please correct if you see an error) See pics.
I have installed the Dakota Trim assembly (Yoke, Jack Screw and Pulley);
*The Bungee Cable fitting is approx 1" closer to the top of the Yoke than the Piper Yoke. This means the Bungee Cable needs shortening by about an inch.
*Also, unless slim fitting Bolts and Nuts are used, it can limit the UP travel of the yoke (nose down trim) against the Turret structure.
*The LOWER elevator spring and bungee cable is generally removed from PA18s.
*The UPPER spring is hotly debated to be for reasons of Certification, Stability or Trim assist and many prefer to fly without it installed.
Questions
1. ELEVATOR CABLE TENSION. Given that I didn’t pay much attention to my Elevator Cables prior to stripping, Im now wondering what sort of tension they should be under? The turn buckles (both) are fully wound in but the Cables still sag to the point they touch the rear cross tube. See pic. I have checked the cable lengths against the originals and they match.
2. ELEVATOR TRAVEL. The lower Elevator cable attach plate (red in drawing) protrudes rearward from the elevator horn and hits the stop limiting the elevator UP travel. It looks as if this plate has been previously fabricated and Im interested to know what size the stock ones are. Being 'shorter' would give me greater adjustment for the above issue...
3. STABILIZER WASHERS. I found a washer/shim on each front Stab attachment where the stab fits on the carry through. As I have a brand new carry through tube which needs to be drilled, Do I need a gap and washers or should I make it so the stab pushes hard up against the carry through fitting?
4. SPRING TENSION. Given I must now shorten my Bungee cable to allow for Dakotas different Yoke mounting, how much spring tension should there be… ie if the STAB is neutral, how much pull is on the Elevators (not flying). Should they too be in a neutral position? Should the Spring slacken and touch the Upper Elev cable when Back stick is applied? see pic below
Questions
