Helmetfire
Caldwell, Texas
Is this solenoid (starter) busted?? It's brand new from spruce, I hooked it all up to check it and found that it wasn't working as I thought it should. You can see in the pic that there is continuity between the RHS coil terminal and the case mount...is this right?? There is no continuity between the two coil terminals. The coil terminals should show continuity and be reversible, correct?
I originally had a ground jumper hooked to one coil terminal (marked "I" on the case), from the master relay, which is the same ground source that activates the master solenoid (from master switch). The other coil terminal was hot, simulating power from start switch. The solenoid wasn't activating in that configuration so I looked a little closer. I found that the solenoid would only activate with a positive wire on the right coil terminal (marked "S" on the case), and the case mount grounded. The weird part was, the left coil terminal would show 12V while activated.
no instructions came with the solenoid. The only markings were "I" and "S" on the coil terminals, and "12V" stamped on the lower right portion of the case mount.
this pic shows my original mounting setup that wasn't working.
