Covering the back of my A-model
NimpoCub
Nimpo Lake, BC . . . AKA "the Floatplane Capital o
Here's what I did to cover the back of my A-model to keep seams on structure:
The fabric just reaches over the top & to the bottom of the D-windows.
I wrapped from the back of the tailpost & seamed @ the leading edge, and down the forward inspection hole U-channel to the top longeron. This is the only unsupported fabric seam, but was well bonded (2" +) because I could reach both sides of the fabric. A 3 or 4" tape will further support the seam.
Then I did the sides, top to bottom longerons, and finally the belly (so I can replace it without releasing the tension on the rest of the fuse.)
I used fabric for a headliner, & light (skinny) naugahide contact cemented to doorskin plywood for side panels. Light & practical, even looks good. :)
...Nimpo Lake fabric shop
NimpoCub said:
the seam.
Did you burn test it first??
Yup I did.
Naugahide burns/drips when held in flame, but goes out when flame removed. (after a few more drips)
Plywood is a bit less flame resistant. :)
She's not fireproof, crashproof, or foolproof, but strong & practical.
I was lucky to find a herd of blue Naugas, so will nearly match the AN Blue exterior!
